vosvos nasıl ama ?
vosvos nasıl ama ?
İleti mygokhan » 22 Oca 2008, 01:36
umarım bunu görebilirsiniz..Ouch
Featured in every VW magazine around the world from the US to Japan, France, the UK and more.
A trophy taker at every event.
And soon to be featured in Lowrider Magazine as well, you just cant get much better than this.
The first thing that strikes you is the color. Its not often you see a Beetle painted Brown.
And this brown is so deep and so smooth it makes you really stop and stare.
Add to that the bright chromework and agressive stance and you just stop in your tracks.
As a bit of a purist myself, I was very pleased to see that for all intensive purposes, this was a stock restoration.
The only deviation being the wheels and lowering. The owner has the factory 16" wheels and the original beam
that could be bolted on in a weekend to make the car back to how Wolfsburg planned it. But obviously with the
jewel finish alloys and the suspension drop it makes a heck of a statement. So you have the best of both worlds.
The Porsche alloys are the ultra-desireable 4 1/2" in front and the "deep 6's" in back.
Fully polished and chromed with detailed center caps and chrome lugs.
4" narrowed front beam with disc brakes in front give it the "tuck" and keep the tires from scrubbing the fenders.
The rear wheels wrapped with 205-70-15 tires for that meaty look
and are bolted to drilled Type 3 drums.
The braking system is a nice upgrade indeed...again something that is a "bolt on" affair
so it would be easy to put it back to original.
The body and paintwork is exceptional.
Mirror finish on all panels, inside, outside and even underneath.
Perfect fit and finish to the body panels and everything.
All the proper early genuine parts.
Correct hood handle, etc.
Ultra- rare door handles, look at the raised part of the casting...ever see these before?
The full three fold ragtop..hard to get more rays of sun than this without a convertible.
This is an original sunroof car by the way, not cut in or modified.
In fact the car was a well known vehicle at the So Cal VW shows before the restoration.
It was always dry and solid and no accidents of note. ALL the body panels on this car are original to the car.
The floor pan has never been welded, and the original engine is still with the car as well.
So not only is it in incredible condition now, it started out as the "virgin" car that we all dream about.
The rare accessories jump out everywhere.
Check out the red tip Hirschmann antenna.
Also note the proper windshield wipers with wire arms and aluminum bases.
Proper solid VW logo.
All the body trim is original VW too, not reproduction stuff.
The car is perhaps the crown jewel of the famed German Folks VW Club.
Its current owner attends all the VW events and the club, which is comprised of only stunning quality cars
with a certain attitude (and altitude) always puts this car front and center in it's displays.
The club plaque
Skoda Fabia 2011 1.2 70 HP
mygokhan
Kayıt: 02 Ağu 2006, 15:05
Ad Soyad: Gökhan
İleti toGah » 22 Oca 2008, 01:38
süper
toGah
Kayıt: 21 Şub 2007, 12:30
İleti by wodoo » 22 Oca 2008, 01:38
evet hocam bunu gördüm LOL gerçektende çok güzel....
paylaşım için teşekkürler...
by wodoo
İleti: 51
Kayıt: 06 Ağu 2007, 17:26
Ad Soyad: Emre Şahin
Arabanız: Astra GSİ
İleti ali » 22 Oca 2008, 01:39
bu vosvoslara niye bu kadar emek harcarlar, anlamış değilim. hastalığı oluyor herhalde.
ali
Kayıt: 27 Haz 2007, 00:27
İleti weyis » 22 Oca 2008, 01:40
güzel
weyis
Kayıt: 21 Kas 2007, 19:22
İleti favo29 » 22 Oca 2008, 01:46
[quote="ali"]bu vosvoslara niye bu kadar emek harcarlar, anlamış değilim. hastalığı oluyor herhalde.[/QUOTE]
Hem de ne hastaları var.Bi görsenConfused
favo29
Kayıt: 09 Arl 2007, 17:36
İleti sılver_exelance » 22 Oca 2008, 01:49
manyaaaaaak yapmış helal olsun
sılver_exelance
Kayıt: 25 Kas 2007, 23:55
İleti loveskoda » 22 Oca 2008, 01:51
Resimleri GöremiyorumCry
loveskoda
Kayıt: 05 Şub 2007, 16:42
İleti by wodoo » 22 Oca 2008, 01:51
bizim burda vardı bitane bunun aynısıydı yalnız bu en eski vw adamlar 20.000 ytl saydılar arabaya sahibide hemen  sattı adamın arabanın antika olduğundan haberi yoktu 20.000 i görünce hemen verdi arabayı LOL
by wodoo
İleti: 51
Arabanız: Astra GSİ
İleti umt_d » 22 Oca 2008, 01:51
Güzelmiş
umt_d
Kayıt: 03 Oca 2008, 20:32
İleti Ufuk KAPLAN » 22 Oca 2008, 01:51
süpermis :)
Ufuk KAPLAN
Kayıt: 10 Mar 2007, 00:59
İleti favo29 » 22 Oca 2008, 01:54
Silecekleri manuel olan modeli bu yanılmıyorsam.
favo29
İleti sonertevfik » 22 Oca 2008, 03:15
DÜNYADA, ŞİMDİYE KADAR ÜRETİLEN, EN KALİTELİ, EN SAĞLAM OTOMOBİLLERDEN BİRİDİR VW KAPLUMBAĞA... HAYRANIYIM. İMKANIM OLURSA ÇOK TEMİZ 74 MODEL BOMBELİ CAM 1303 BİG KAPLUMBAĞA ALIP 0 KM AYARINDA YAPMAK İSTİYORUM... TAM BİR KLASİK...  HAYALLERİMİ SÜSLEYEN BİR OTOMOBİL...
sonertevfik
İleti: 311
Kayıt: 09 Tem 2007, 21:55
Ad Soyad: Soner Tevfik
Arabanız: Skoda Felicia GLX-İ
İleti demir_01 » 22 Oca 2008, 03:19
BU ARABANIN MOTORU PORCHE MOTORUMU ACABA
demir_01
Kayıt: 10 Kas 2007, 20:19
İleti yonetici » 22 Oca 2008, 11:12
Binmeye değer bir hal almış en sonunda.
İleti fabia_2008 » 22 Oca 2008, 12:38
Paylaşım için teşekkürler... Motoru gıcır gıcır süper olmuş acaba güçlü mü motorla oynanmış mı?
fabia_2008
Kayıt: 13 Oca 2008, 00:23
İleti BlueVRS » 22 Oca 2008, 12:54
özellikle motor kısmı çok güzel ama ben tosbiş de sarı yada kırmızı seviyorum siyah kesinlikle sevimli olmamış bu araçta bana göre vosvos sevimliliği ile ön plana çıkan bir araç olduğu için siyah olmamış heralde ben ilk kez siyahını görüyorum.
BlueVRS
Kayıt: 15 Oca 2008, 17:17
İleti FLEYLAK » 22 Oca 2008, 16:37
Gerçekten çok güzel olmuş,yapmış elin oğlu...
FLEYLAK
Kayıt: 22 Kas 2007, 13:13
