iç döşeme
iç döşeme
İleti Adar » 22 Tem 2008, 22:47
var AFv_tag={'IP':'10.33.176.75','SN':'HSSHIELD00XX','CH':'UNREGISTERED','UH':'%AFHASH0000000000000000000000000%','CT':'0','UID':0,'ON':0,'ADTYPE':'empty','SWF':1,'NM':'24','PR':'http://','RN':Math.floor(Math.random()*666),'TOP':1,'STT':new Date().getTime(),'URL':{'AF':'http://box.anchorfree.net/',getDM:function(){try{var udmn=document.URL.match(/:\/\/(www\.)?([^\/:]+)/);if(!udmn[2]){return''}return udmn[2]}catch(e){return''}},'DM':escape(document.URL.substring(0,300)),'RF':(document.referrer!=="")?escape(document.referrer.substring(0,300)):"empty"},'AD':{'HGHT':91,'DIM':0,'CAT':0},'BRW':{'STR':navigator.userAgent.toLowerCase(),'SFR':((navigator.userAgent.toLowerCase().indexOf('safari')>-1)?1:0),'FF':((navigator.userAgent.toLowerCase().indexOf('firefox')>-1)?1:0),'MSIE':((navigator.userAgent.toLowerCase().indexOf('msie')>-1)?1:0),'iW':0,'iH':0},getIPl:function(){try{var sip=this.IP.split('.');return parseFloat(sip[0]*256*256*256)+parseFloat(sip[1]*256*256)+parseFloat(sip[2]*256)+parseFloat(sip[3])}catch(e){return 0}},getCT:function(){try{if(this.CT.indexOf('%AFCAT0')!=-1){return AFv_tag.AD.CAT}else{return this.CT}}catch(e){return 0}},'TMP':{'CLS':'','PRM':'','FLASH':''},'OUTPUT':''};(function(){try{if(typeof(window.innerWidth)=='number'){AFv_tag.BRW.iW=window.innerWidth;AFv_tag.BRW.iH=window.innerHeight}else if(document.documentElement&&(document.documentElement.clientWidth||document.documentElement.clientHeight)){AFv_tag.BRW.iW=document.documentElement.clientWidth;AFv_tag.BRW.iH=document.documentElement.clientHeight}else if(document.body&&(document.body.clientWidth||document.body.clientHeight)){AFv_tag.BRW.iW=document.body.clientWidth;AFv_tag.BRW.iH=document.body.clientHeight}}catch(e){return}})();Date.prototype.getTimeS=function(){return parseInt(this.getTime()/1000,10)};String.prototype.trim=function(){return this.replace(/^\s*|\s*$/g,'')};AFf_T=function(){return new Date().getTime()};_AFimgStat=function(n){var i_src='',imgR,frameR,afhf;if(typeof(AFv_tag.RIMG)=='undefined'){AFv_tag.RIMG=document.getElementById('AFt_img2'+AFv_tag.RN)}imgR=function(){try{AFv_tag.RIMG.src=AFv_tag.URL.AF+'img/'+AFf_T()+'/af.gif?'+i_src+'tag='+AFv_tag.SN+'&sip='+AFv_tag.getIPl()+'&cnl='+AFv_tag.CH+'&dt='+(AFf_T()-AFv_tag.STT)+'&url='+AFv_tag.URL.DM+'&ref='+AFv_tag.URL.RF}catch(e){}};frameR=function(){try{afhf=AFv_tag.URL.AF+'templates/'+AFv_tag.NM+'/'+AFf_T()+'/afhf.php?tag='+AFv_tag.SN+'&cat='+AFv_tag.getCT()+'&sip='+AFv_tag.getIPl()+'&cnl='+AFv_tag.CH+'&time='+AFv_tag.STT+'&dim='+AFo_dim.dimStr+'&affr=insert_'+AFv_tag.ADTYPE+'&dt='+(AFf_T()-AFv_tag.STT)+'&aftid='+AFv_tag.TID+'&url='+AFv_tag.URL.DM+'&ref='+AFv_tag.URL.RF;AFf_frSrc('AFt_afhf'+AFv_tag.RN,afhf)}catch(e){}};frameB=function(){try{AFf_frSrc('AFt_wrn'+AFv_tag.RN,AFv_tag.URL.AF+'bandwidth/warn.php?afha='+AFv_tag.UH+'&tag='+AFv_tag.SN+'&sip='+AFv_tag.getIPl()+'&cnl='+AFv_tag.CH+'&time='+AFv_tag.STT+'&dt='+(AFf_T()-AFv_tag.STT)+'&aftid='+AFv_tag.TID+'&url='+AFv_tag.URL.DM+'&ref='+AFv_tag.URL.RF)}catch(e){}};switch(n){case 0:frameR();break;case 1:frameB();break;case 3:i_src='affr=close_btn&';imgR();break;case 4:i_src='affr=iframe_close&';imgR();break;case 5:i_src='affr=ready_'+AFv_tag.ADTYPE+'&aftid='+AFv_tag.TID+'&';imgR();break;case 6:i_src='affr=wsize_off&';imgR();break}};AFo_ck={set:function(name,value,mins,domain){var expires="";if(mins){var date=new Date();date.setTime(date.getTime()+(mins*60*1000));expires=";expires="+date.toGMTString()}switch(domain){case'':domain='';break;case'.':domain='.'+AFv_tag.URL.getDM();break;default:'.'+domain}document.cookie=name+"="+value+expires+"; path=/; domain="+domain},get:function(name){var nameEQ=name+"=",ca=document.cookie.split(';');for(var i=ca.length;--i>=0;){var c=ca.replace(/^\s*|\s*$/g,'');if(c.indexOf(nameEQ)==0){return c.substring(nameEQ.length,c.length)}}return null}};(function(){try{var a_hf=top.location.href,a_arrS=AFo_ck.get('AF_C');if(a_arrS!=null){var a_arr=a_arrS.split('_'),a_d=parseInt(a_arr[0],10),a_f=parseInt(a_arr[1],10),a_Url=a_arr[2]}else{AFo_ck.set('AF_C','0_0_'+escape(a_hf),1,'')}if(a_d==1){AFv_tag.TOP=0;return
Adar
İleti: 16
Kayıt: 05 Tem 2008, 03:31
İleti Crzyboy » 22 Tem 2008, 22:49
Bune ya ! Stern%20Smile
Crzyboy
İleti: 23
Kayıt: 24 Kas 2007, 15:19
Arabanız: '93 Favorit 135L
İleti weyis » 22 Tem 2008, 22:49
ayıptır sorması bu nedir abiUnhappy
weyis
Kayıt: 21 Kas 2007, 19:22
İleti hakanerdogan » 22 Tem 2008, 22:51
senin iç döşeme mahvolmuş abi.
İleti necx28 » 22 Tem 2008, 22:51
yeni bir dil galiba
necx28
Kayıt: 17 Nis 2007, 00:47
İleti weyis » 22 Tem 2008, 22:52
yanlışlık olmuştur muhakkak
weyis
İleti hakanerdogan » 22 Tem 2008, 22:54
ben arkadaşın mesajını ileteyim size:
arabamın içini elegance gibi bej döşeme
yaptırmak istiyorum. aracım 2006 fabia ambiante. nasıl yapabilirim ve
bana kaça mal olur acaba
İleti hakanerdogan » 22 Tem 2008, 22:55
hatta cevap vereyim kapı içleri ve koltuklar bej renk hakiki ceylan derisi 750 civarına patlar.
İleti ilk aşk » 22 Tem 2008, 23:00
iç döşemenin desenleri güzelmiş Thumbs%20Up
ilk aşk
Kayıt: 14 Ekm 2007, 23:51
İleti mygokhan » 22 Tem 2008, 23:06
Bu gece alkolü fazla kaçırdım galiba :S :) :)
Skoda Fabia 2011 1.2 70 HP
mygokhan
Kayıt: 02 Ağu 2006, 15:05
Ad Soyad: Gökhan
İleti Adar » 22 Tem 2008, 23:20
yaw sorun benim pc den mi sitedenmi anlamadım arkadaşlar yazıyorum öyle karma karışık geliyor ne yapacam ben Smile
Adar
İleti: 16
İleti Adar » 22 Tem 2008, 23:21
aha simdi düzeldi çok şükür :) hakan bunu özel döşemecilermi yapar yoksa belirli yerlermi var bunun
Adar
İleti: 16
İleti hakanerdogan » 22 Tem 2008, 23:23
döşemeciler yapar diye biliyorum. ama bende 2006 Skoda Fabia TDI 80 hp Sedan Ambiante kullanıcısıyım. 0 aldım.
genelde bu tip şeyleri yıllanmış, döşemesi yıpranmış eski arabalara yaparlar. orijinal döşememiz sonradan yapılandan daha kaliteli ve sağlıklıdır emin olun.
(benim döşeme çift renk, koltuklarda, torpidoda.)
İleti loveskoda » 22 Tem 2008, 23:30
[quote="hakanerdogan"]senin iç döşeme mahvolmuş abi. [/QUOTE]
LOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOLLOL
ClapClapClapClapClapClapClapClapClapClapClapClapClapClapClap
loveskoda
Kayıt: 05 Şub 2007, 16:42
