OCTAVİA KONFOR PAKETİ ÖZELLİKLERİ
İleti fyyaman » 14 Mar 2009, 18:56
Yapılabilecekler listesi(alıntıdır):
Puddle lights on door mirrors(yan aynalardaki ışıkları aktif yapma)
42 – Door electric (driver)
07 - Recode
Should read 756 on ambiente models
To add Puddle lights +2 (758) (Std on Elegance)
Steering weight(direksiyon ağırlığı)
44 – Steering assist
10 - Adaption
Channel 1
Should read 5 on non Vrs models. Pick a number between 1 & 6 for steering
weight
For auto lights(otomatik yanan ışıklar,farlar sensörlü ise)
DISCLAIMER: you need rain sensor wipers and test with someone elses
tunnel light switch before you buy one as it may not work properly
09 – Central electrics
Long coding (07) , click yes when asked
Byte 1 – highlight ‘assistance driving light_leaving home active’and ‘coming
home active.’
Transfer coding.
Single door unlock(tek kapı açma-kapama)
46 – central convenience
10 - Adaption
Channel 3
1= on, 0=off
Anti hijack(kapıların otomatik kilitlenmesi.).
Auto lock
10 - Adaption
Channel 4
1= on, 0=off
Auto unlock (when you take keys out of ignition)
10 - Adaption
Channel 5
1= on, 0=off
Alarm horn change(alarm tipini değiştirme)
10 - Adaption
Channel 13
1= Rest of world
2=UK
Activate cruise control(El gazını aktifleştirme)
16 – Steering wheel
07 – Recode
00xx?x
0 = no CC or maxidot
1 = no CC with Maxidot
2 = with CC, no maxidot
4 = With CC and maxidot
Instument options
(cam suyu-emniyetkemeri uyarısı-fren balatası bitimi uyarıları)
17 – instruments
07 – recode
00??x0x
00 = no options
+01 = brake pad monitoring
+02 = Seat belt warning
+04 = Washer fluid warning
(add the option numbers together for the right number i.e: all three = 07 or to
turn off seatbelt warning 01+04=05)
Long coding options (other stuff is possible, but either not worth it or
a bit dodgy)
Central electrics (09) (Long coding options)
fyyaman
Kayıt: 31 Mar 2007, 10:45
Ad Soyad: Yalçın YAMAN
Arabanız: Octavia
İleti fyyaman » 14 Mar 2009, 21:25
Enabling Cornering Light Function(sisleri sinyallerle yakma)
One of the current 'trendy' features is to have Cornering Front
Lights.  Depending on the version of Central Electronics Controller
fitted to your car it is entirely possible that this function is
already present on your car and it can simply be switched on.
Tools Required - VCDS (VAG-COM)
Applicable Cars - Octavia II and other A5 Platform cars.
To do this first connect your VCDS to the car and carry out and save a full Autoscan.
Currently I have only tested this on the Central Electronics
Controller 3C0 937 049 AJ so you will need to identify the controller
you have fitted to you car.
Open controller number 09 and look at the part number in the field marked VAG Number.
09_Cent_Elec_3C0_Open_Controller
With the controller open select Coding 07 which will open a new window like this
09_Cent_Elec_3C0_Recode_Module
From this screen you'll need to select Long Coding Helper which should look something like this
09_Cent_Elec_3C0_Long_Code_Helper_FogLightCornering
As you can see we have to change Byte 23, Bit 2 and Bit 3-4.  Bit 2
simply requires a tick in the check box and Bit 3-4 is a drop down list
where you should select 08 Turn Lights via Fog Lights.
Once you've made the change choose Exit to close Long Coding Helper
and copy the code back to the Recode Module screen.  Once in the Recode
Module Screen you should see the new long code inserted into the white
box.  Choose Do It and VCDS will validate the code before writing it to
the controller and returning you to the Open Controller screen.  At
this point it's always worth doing a quick check for stored fault codes
that might relate to the changes you've made.
To activate the Cornering Function simply switch on the headlights
and turn the steering wheel, it is better to carry this out with the
engine running as the steering is easier to turn.  You should see that
the front fog lights will illuminate at varying levels depending on the
steering wheel position.
Please note that the functions and bit/byte locations may vary
depending on which version of controller you have. If you find a
variation please contact me with full details and the VAG part number of the controller and I will add it to these instructions.
fyyaman
Arabanız: Octavia
İleti fyyaman » 14 Mar 2009, 23:18
Octavia A5 için kodlamalar(Sayfayı Türkçe'ye çevirtebilirsiniz, çok iyi olmasada),
orjinali Almanca : http://de.openobd.org/skoda/octavia_1z.htm
Çevirmek içinde: http://translate.google.com
fyyaman
Arabanız: Octavia
İleti fyyaman » 24 Mar 2009, 02:40
Arkadaşlar, Bu ön sislerin sinyallerle yanmasını sağlayanSeçenekten Long Code Helperde  "Byte23" menüsüne Binary de kullanarak ulaşamıyorum;Byte 17 de bitiyor Binary kullanarak Byte19 a kadar ulaşabildim.Aranızda Ulaşan varmı? Benim Araç 2005 Elegance
fyyaman
Arabanız: Octavia
İleti ilgazdr » 24 Mar 2009, 03:00
sayın fyyaman,yaptığınız paylaşımlar için çok teşekkür ederiz.Forumu kullanan arkadaşların işine oldukça yarayacaktır.
Sorunuza gelince;Bildiğim kadarıyla bahsettiğiniz özelliğe sadece 2009 model araçlarda ulaşılabiliyor.Daha önce bu konu tartışılmış ve isnilgiz beyde 2006 model aracında denemiş ve açılamadığını söylemişti.
ilgazdr
İleti: 74
Kayıt: 23 Tem 2007, 13:01
İleti fyyaman » 25 Mar 2009, 00:11
Yanıtınızdan dolayı teşekkür ederim.
Aslında söylemek istediğim 2009 dan aşağı  modellere de herhangi bir flash yazılımı yapılabilirliğiydi....Bu da sanırım yapılamıyor muş...Yani benim o özelliği açabilme şansım yokmuş
fyyaman
Arabanız: Octavia
İleti ilgazdr » 16 Haz 2009, 14:52
Arkadaşlar Uzun bir süredir buraya ekleme yapmamıştım.Az önce forumu incelerken OCTUPUS arkadaşın bulduğu ve benim bilmediğim bir özelliği gördüm.Hemen bu başlık altına eklemek istedim.
ALINTIDIR;
"Yağmur sensörü kullandıktan sonra ,camlar aralık veya açık iken arabayı kilitlediğinizde,yağmur varsa aracın camları otomatik olarak kapanmaktadır."
ilgazdr
İleti: 74
İleti ilgazdr » 03 Ekm 2009, 13:30
Forumdaki bir arkadaş bu özellikleri merak ediyordu ve konuyu bulamamıştı.Bu nedenle konuyu başa taşımak istedim.
ilgazdr
İleti: 74
İleti MEGAN » 03 Ekm 2009, 18:00
Merak eden arkadaş ben oluyorum :)
 Teşekkür ettim bilgiler için fakat bunları bir ara toparlamak lazım çok dağılmşşş :D
-Skoda Octavia A5 1.6 FSI //
-34 EU 8105
MEGAN
Kayıt: 16 Arl 2008, 00:27
Ad Soyad: MEHMET ÖZCAN
İleti ilgazdr » 03 Ekm 2009, 18:18
Aynı fikirdeyim.Fırsatım olunca toparlayacağım.
ilgazdr
İleti: 74
İleti MEGAN » 03 Ekm 2009, 18:38
mail atarsanız yardımcı olurum toplamanızda. Ek olarak bilgilerde toplarız gerekirse Gif. resimleri ile destekleriz gif. elimden gelir :)
PS-Gif-FLash    bunları az çok biliyorum yaparsak adam gibi birşey olsun bari :)
-34 EU 8105
MEGAN
İleti zemheri » 03 Kas 2009, 03:08
arkadaşlar hepinize paylaşmış olduğunuz bilgilerden dolayı teşekkür ederim. siteyi yeni keşfettim. 1 saattir de sadece bu başlığı okudum. ben de 2 ay önce 2006 model octavia elegance aldım. ve beyinle ilgili birtakım problemler yaşıyorum. öncelikle uzaktan kumandam çalışmıyordu buradaki servise gittim (büyükçekmece\istanbul) çözemediler. ben de sanayii de özel bir servise gittim. comfor beyninde arıza olmuş tamir ettik dediler 300 tl aldılar ama araç 1 gün kaldı. daha sonra yine aynı şekilde bozuldu tekrar tamir ettiler. şimdi koltuk hafızasın da problem var acaba aynı beyinden mi kaynaklanıyordur? bir de bi ara winter tyres tı galiba hız uyarısını açma onu bir ara 100 km hız sınırına getirmiştim 100 km hızı geçince uyarı veriyordu. şimdi onu silmeme rağmen hala uyarı çıkıyor. ayrıca elegance modellerinde yokuş kalkış destek sistemi olduğu söyleniyor. gösterge de işareti var ama ben de çalışmıyor bir de sabit hız kontrolü devrede iken göstergede ışığının yanması gerekiyormuş o da yanmıyor... çok yazdım belki kusuruma bakmayın. görüşmek üzre
zemheri
Kayıt: 03 Kas 2009, 02:37
İleti ilgazdr » 08 Kas 2009, 17:28
Sayın zemheri geç cevap için özür dilerim
2006 elegance A5 kasa aracımda göstergede ne yokuş kalkış destek sistemi ne de sabit hız kontrolü için bir uyarı ışığı mevcut değil.
Multidot bilgi ekranında ayarlar bölümüne girdikten sonra yaptığın değişiklikleri onaylayıp o şekilde çıkman lazım.Eğer hız sınırı uyarısını sildiysen daha sonra göstergedeki özellikler arsında dolaşırken hız sınırına geldiğinde "--------" seklinde görülmesi lazım.Hala "100" yazıyorsa silinmemiştir.Winter tires başka bir özellik.
ilgazdr
İleti: 74
İleti jenq » 12 Arl 2009, 01:13
Arkadaşlar bugün ilginç birşey keşfettim.
Hava yağmurluydu silecekler fasılalı değilde 2. kademede çalışıyordu. Yani yaklaşık 1 sn de bir siliyordu. Sonra kırmızı ışıkta durduğumda silecekler 5 sn de bir silmeye başladı. Sonra hareket ettiğimde tekrar 1 sn. de silmeye devam etti. Adamlar neyi düşünmüşler vay be :)
jenq
İleti: 103
Kayıt: 20 Tem 2009, 21:25
Arabanız: Skoda Octavia III Optimal 1.6 TDI DSG
İleti MEGAN » 12 Arl 2009, 01:30
[quote="jenq"]Arkadaşlar bugün ilginç birşey keşfettim.
Hava yağmurluydu silecekler fasılalı değilde 2. kademede çalışıyordu. Yani yaklaşık 1 sn de bir siliyordu. Sonra kırmızı ışıkta durduğumda silecekler 5 sn de bir silmeye başladı. Sonra hareket ettiğimde tekrar 1 sn. de silmeye devam etti. Adamlar neyi düşünmüşler vay be :)[/QUOTE]
ARAÇ?
MODEL?
YIL?
-34 EU 8105
MEGAN
İleti jenq » 12 Arl 2009, 01:36
[quote="MEGAN"][quote="jenq"]Arkadaşlar bugün ilginç birşey keşfettim.
ARAÇ?
MODEL?
YIL?
2007 model Skoda Octavia Ambiante A5
jenq
İleti: 103
İleti umutkubat » 12 Arl 2009, 02:42
5 senedir bu aracı kullanıyorum bu özelliği geçen hafta keşfettim:) (2005 Ambiante)
umutkubat
Kayıt: 26 Kas 2005, 20:09
İleti WXW » 12 Arl 2009, 02:46
hız sabitleyici benim gösterge panelinde var ancak "hill hold" (yokuş kalkış sistemi) de panelde çıkıyor mu hiçdikkat etmedim.ilginç
WXW
İleti: 346
Kayıt: 07 Nis 2009, 00:57
Ad Soyad: Serkan
