Corner Fonksiyonu
Corner Fonksiyonu
İleti myavuz » 23 Nis 2009, 01:56
merhaba arkadaşlar.. Forumun yenisiyim bayaadır kafama takılan bi mevzuu var 2009 elegance mpi var bu corner(dönüşlerde sisleri yakma) olayı bende mevcutmu mevcutsa nerden açılıyo bu sinir oldum servise sordum fonksiyonun ne olduğundan bi haberler
myavuz
Kayıt: 23 Nis 2009, 01:04
İleti hakanerdogan » 23 Nis 2009, 02:32
viraj özellikli sis farı makyajsız kasa A5 lerde yok diye biliyorum.
İleti myavuz » 23 Nis 2009, 02:56
Saol dostum
myavuz
İleti aekaragoz » 24 Nis 2009, 15:40
Bende araştırmıştım. 20o9 elegance larda maalesef bu özellik yok.
aekaragoz
İleti: 103
Kayıt: 02 Haz 2006, 21:50
Arabanız: Skoda Superb
İleti isikayhan » 24 Nis 2009, 16:24
sanırım 2009 makyajlı(facelift) sis farlı modellerde(elegance) var:
http://new.skoda-auto.com/Com/Documents ... -m0133.htm
Fog lights with the function “Corner”*The fog lights with the function “Corner” improve the illumination of areas close to the vehicle when turning, parking etc.
The fog lights with the function “Corner” are regulated according to the steering angle or after switching on the turn signal light1) in the following circumstances:
• the vehicle is stationary and the engine is running or it moves with a speed of maximum 40 km/h;
• the daylight driving lights are not switched on;
• the low beam is switched on or the light switch is in the position AUTO and the intensity of the ambient light causes the low beam to be switched on;
• the fog lights are not switched on;
• no reverse gear is engaged.
 Note
If you engage the reverse gear during the active function “Corner”, both fog lights illuminate.
1) If both switch on versions are conflicting, for example if the steering wheel is turned to the left and the right turn signal light is switched on, the turn signal light has the higher priority.
http://new.skoda-auto.com/SiteCollectio ... ue_ENG.pdf
3. Front fog lamps are another impressive
and attractive detail for the front of the car,
as their shape contributes to the dynamic feel
of the vehicle. Regarding functionality they are
available in four versions. The top fog lamps
on offer feature the Corner functionality
and daytime running lights, “Day Light”.
The Corner function can be activated when the
fog lamp switch is off (but the main headlamps
are on) and the car speed is up to 40 km/h.
Depending on the position of the steering
wheel or activated indicators, one of the fog
lamps will self-activate, so that the driver is
warned of obstacles on dark roads, including
kerbs. The daytime running light function as
a part of the fog lamp is a new feature in
Octavia equipment. The major advantage
is economy, because compared to the
lower beams usually used for daily lights
the fog lamp bulbs have much lower power
consumption.
Bilgi paylaştıkça çoğalır.
M.Niyazi Saral
isikayhan
İleti: 815
Kayıt: 18 Tem 2007, 03:13
İleti alpino » 24 Nis 2009, 19:22
arkadaşlar bu özellik 2009 model makyajsız a5 elegance aracımda var. haliyle sizde de vardır
zira benim araçta şu an mevcut. yalnız yetkili serviste bilgisayara bağlayarak açılabiliyor ve bu özelliği her servis bilmiyor. ankara ünaldı skoda'da elektrik ustaları açtı. inanılmaz kullanışlı bir özellik.
İleti: 1121
İleti hakanerdogan » 24 Nis 2009, 19:25
servisler bi alem, ben yok biliyordum.
geçirdiğim kazadan sonra anahtardan kilidi açıp kapılara dokunmadan bagajdan bişi alınca elin dolu olur diye kendi geri kilitleniyor, kilitlenmemeye başladı.
diyom böle böle, öle bi özellik yok diyolar. la havle... anlatıyom, yok o ne? biz hiç görmedik...
İleti isikayhan » 24 Nis 2009, 22:30
aşağıda yazanlara göre 2008 modelden itibaren sis aynalı modellerde (rs ve scout hariç) corner function'ın olması lazım:
http://octinfo.com/index.php?p=octavia2_MY_en
MY2008:
Front fog lights with "Corner" function (following curves) available except RS and Scout.
general differences between MY 2007 and 2008 are as following:
-Front fog-lamps with „Corner“ function : for all trims excl. RS and Scout
videosu da var (hatta rs'lere bile uygulanmışının videosu var):
son videonun yorumlarında yazanlara göre 2008 modellinden itibaren merkezi elektrik ünitesince bu foksiyon destekleniyormuş VAG veya VAS ile kodu ile aktif edilebiliyormuş:
It is a feature that supports the central electric control unit from model year 2008. For the older models is needed to replace a new unit. Then, just using VAG or VAS for coding it.
M.Niyazi Saral
isikayhan
İleti: 815
İleti isikayhan » 24 Nis 2009, 22:55
VAG-COM ile nasıl yapılacağı hakkında bilgi ve resim verilen bir yer buldum (ingilizce)
http://briskoda.net/octavia-ii/octavia- ... ost1424912
resimleri görmek için siteye üye olmak lazım:
It may depend on the controller you have in the car -
http://briskoda.net/attachment.php?atta ... 1220726454
Open Coding 07 and use the Long Coding Helper
Byte 23 Bit 2 should be ticked and Bit 3-4 changed to 08.
M.Niyazi Saral
isikayhan
İleti: 815
İleti isikayhan » 24 Nis 2009, 23:51
daha ayrıntılı anlatımı olan ve üyelik gerektirmeden resimlerin görüldüğü bir sayfa daha buldum:
http://octavia-vrs.com/cms/content/enab ... t-function
M.Niyazi Saral
isikayhan
İleti: 815
İleti octaviaman » 25 Nis 2009, 19:39
Bu servisler ya araçları bilmiyor ya da model de ne varsa onu uygulamaya çalışıyorlar herhalde.ne sorsam yok bu özellik diyorlar.
octaviaman
İleti: 679
Kayıt: 05 Eyl 2008, 13:38
