nedir bu kilmanın özelligi
İleti elegance » 07 Tem 2008, 02:13
arkadaşlar bi tane forumda gördğm bu bizim climatroniklerde su varmış arabın kliması maxi dot gibi olyomuş bakında resmi
buda 72 ye yakın özellligi ingilizce bazılrında 44 müş ama ingilzce bunların türkcesi neki hiç yapan varmı
. System error
2. Actual value feeler virtually
3. Actual value interior feeler console
4. Actual value outside temperature - feeler wasserkasten
5. Actual value outside temperature - feeler bumper
6. Actual value blowing out feeler floor space
7. Actual value blowing out feeler man Anstroemer
8. Display check
9. Actual digital value acknowledging potentiometer temperature flap
10. Target digital value temperature flap
11. Actual digital value acknowledging potentiometer A/C flap
12. Target digital value A/C flap
13. Actual digital value acknowledging potentiometer Fuss/Def flap
14. Target digital value Fuss/Def flap
15. Actual digital value acknowledging potentiometer ram air flap
16. Target digital value ram air flap
17. Driving speed (km/h)
18. Actual value of the blower tension (volt)
19. Desired value of the blower tension (volt)
20. Actual value of the compressor/on-board tension (volt)
21. Number of low-voltage events
(not volatilely)
22. Switching status of the high pressure switch
23. Number of high pressure events (volatile)
24. Number of high pressure events (not volatile)
25. A/D value kickdown switch
26. A/D value hot light
27. Engine speed
28. Compressor number of revolutions
29. Coding
30. Software-Version
31. Software index
32. Potentiometer error counter temperature flap
33. Potentiometer error counter A/C flap
34. Potentiometer error counter Fuss/Def flap
35. Potentiometer error counter ram air flap
36. Temperature flap notice cold
37. Temperature flap notice warm
38. A/C flap notice closed
39. A/C flap notice opened
40. Fuss/Def flap notice Def
41. Fuss/Def flap notice foot
42. Ram air flap notice up
43. Ram air flap notice too
44. Operating cycle counter
45. Interior temperature counted (Ninc) dig
46. Outside temperature filtered (°C)
47. Outside temperature not filtered (°C)
48. ECOR
49. Coolant temperature
50. Service life in min
51. Engine temperature °C
52. Compressor switching off conditions
53. Announcement more actively el. Exits:
Compressor/circulating air valve/water valve
54. Rule index
55. Outside temperature °C
56. Interior feeler virtually °C
57. Interior feeler console °C
58. Temperature wasserkasten °C
59. Temperature bumper °C
60. Blowing out feeler floor space °C
61. Blowing out feeler man Anstroemer °C
62. Sun intensity W/m-1
63. Sun intensity filtered W/m-1
64. Delta exhaust rise
65. Delta A/C Klappenverschiebung
66. Time constant/1.6 seconds
67. Cold weather starting correction
68. Maximum correcting variable for i and p-portion
69. Actual value blowing out feeler foot (cnts)
70. Desired value blowing out feeler foot (cnts)
71. Deviation (Epsilon)
72. Portion (+ heat/- cool)
motor hızını motor sıcaklıgını iç dış sıcaklıgı vs görebiliyormusuz
elegance
İleti: 211
Kayıt: 15 Şub 2008, 22:40
Ad Soyad: uğur
Arabanız: Octavia TDI
İleti ilk aşk » 07 Tem 2008, 02:21
amma karışık
ilk aşk
Kayıt: 14 Ekm 2007, 23:51
İleti PİCK-UP » 07 Tem 2008, 02:29
karışık işler sen en iyisi konu başlıgının yanına parantez içinde oktaviacılar yaz onlar sana daha yardımcı olabilir.
İleti yonetici » 07 Tem 2008, 12:23
Bu elektronik klima benimde cordobada var ama şekli böyle değil. Benim anladığım kadarıyla dereceyi dijital ekranda belirlemeniz ve aracın içini otomatik olarak o sıcaklığa getirmeye çalışmaktan başka bir farkı yok. Mesela ben aracı ilk çalıştırdığımda içerisi sıcak olduğundan klima çok fazla hava üflüyor zamanla havanın dozunu düşürüyor gerekirsede sıcaklığı arttırıp azaltarak belirlediğim dereceye sabitlemeye çalışıyor.
İleti elegance » 07 Tem 2008, 12:26
[quote="?"]Bu elektronik klima benimde cordobada var ama şekli böyle değil. Benim anladığım kadarıyla dereceyi dijital ekranda belirlemeniz ve aracın içini otomatik olarak o sıcaklığa getirmeye çalışmaktan başka bir farkı yok. Mesela ben aracı ilk çalıştırdığımda içerisi sıcak olduğundan klima çok fazla hava üflüyor zamanla havanın dozunu düşürüyor gerekirsede sıcaklığı arttırıp azaltarak belirlediğim dereceye sabitlemeye çalışıyor.[/QUOTE] yok hocam bu arabayı ısıtırken bunlara basarsanhızını falanda gösteriyomuş o gösterdigim 72 özelligin türkcesi neyse onları gösteriyomuş
elegance
İleti: 211
Ad Soyad: uğur
İleti elegance » 07 Tem 2008, 12:41
ahada buldum başka bişi ararken
elegance
İleti: 211
Ad Soyad: uğur
İleti yonetici » 07 Tem 2008, 12:51
Ben o özelliklerden bahsedildiğine bakmamışım klimayı soruyorsunuz sandım. Evet bu özelliklere klimanın gizli özellikleri diyorlar. Otomatik klima olduğu için tüm bu değerlere bakarak çalışıyor ve gizli menüsünden bu sensör değerlerine ulaşabiliyorsunuz. Yalnız bu klimanın octaviada olduğunu hiç görmedim eski volkswagen bora, passat modellerinde var.
İleti elegance » 07 Tem 2008, 12:54
octavia a4 kasa elegancelerin hepsinde bundan varda yukarda 72 tane madde var ya onların türkçesi ne demek
elegance
İleti: 211
Ad Soyad: uğur
İleti BlueVRS » 07 Tem 2008, 13:24
Bizim sattığımız passat'ın ekranı da aynı böyle idi..
BlueVRS
Kayıt: 15 Oca 2008, 17:17
İleti maozkan64 » 23 Tem 2008, 12:50
Benim arabadaki climatronik klimada 60 madde var. Sitenin birinde bu 60 maddelik listeyi buldum. Bulduğum liste vw lerin, ama aynı grup araba olmasına rağmen tam uymuyor. 16. maddedeki hız ölçer aynı ama...
Octavia Collection 2004
maozkan64
İleti: 42
Kayıt: 19 Tem 2008, 17:39
İleti kadir_ » 23 Tem 2008, 15:04
elegance bu arada denedim dijital hız olarak 5 km/h lik fark bendede var  birde çabuk tepki veremiyor
